Got every light but signals. Not even as in "on but won't blink" but as in no lights when in signal mode. On dash or at rear. car came with glove box overflowing with fuses. Can I rig a bypass or someone tell me where to start?
Discussion Starter #2
Well thanks to all who jumped in.
Got power in all fuses that are to have power whether key on or key off fuses. At the semi circle plug to colum I only have yellow showing good power to horn and a pale blue barely lighting tester. Before I shred dash if anyone knows of a likely braking point between fuse box and connector at column base PULEESE sound out.
Sounds like the the turn signal switch in the column is bad. You can pull the steering wheel to check the condition of the switch.
Wow theres life
Took wheel off hooked seperate battery and ran jumpers.All fine. Found the two wires supposed to supply power to switch,,,,DEAD, but power at fuse. So traced signal back and spliced in and spliced to horn supply for hazard. All good now
THANKS
