in 69 ford used a set of adaptor soacers that went onto the front of the head which allowed toy to use the 302 accessories....this is stock. i got a set of world windsor sr heads chead but the holes are different and the spaces/adaptors don't match.
so is there a way to make this work?
here is a pic...
http://www.trinitysmustangs.com/ericstang/100_0683.jpg
the top head is stock, the bottom is the world. in the bottom head, the top hole is a plug??? any suggestions?
· Premium Member
I think most of the small block heads (Ford) from 78 up have an adapter that screws into the hole kind of like a heli coil, they use them on the front of the heads and bolt the air injection to the rear. If you find a good Ford parts man he should be able to get them. Sometimes you can extract them from a used head. Strange they were not included with the heads.
http://www.worldcastings.com/tech/WindsorJrTech.pdf
interestingly enough, i bought these heads used so i didn't have the instruction sheet that goes with them. well i found it (above) online and the piece was listed on it (bottom left under...accessories). 50 dollars later and calling a few area ford dealers got me the patt. it was a helicoil looking thing that went into the hole. thanks for the good advice....it was right on the money....50 bucks for these 2 little plugs!
but you gotta do what you gotta do, ya know.
i feel kinda dumb but if i had the sheet in the first place it wouldn't of been a problem.
<font size=-1>[ This Message was edited by: sg69 on 5/7/06 3:51am ]</font>
<font size=-1>[ This Message was edited by: sg69 on 5/7/06 3:52am ]</font>
