Bough headers for it but would not bolt on? different bolts pattern, when ordering headers what should I order for?
Pancho,
You likely need to buy headers for a GT.unibody head. You are lucky the bolts didn't line up, because the port location is different too, you likely would never had got the gasket to seal for more than a couple months
However, to help better can you get the casting number off the head between the two center spark plugs? They should be C6AE-R, C7AE-A, C8AE-H or something like that. There may be the number 6090 between them too.
Also, let me know what you bought for headers already. Part number would be best
Unfortunately, if you do have original GT/unibody heads, the only real option is from FPA and they are very expensive. However they are very nice too.
B- F.E. Available in 16 bolt C.J./ 14 bolt GT/ 8 bolt Std. flanges
