I have had my new Cougar for a couple of years now. About a year ago the stockish engine in it took a dump.
The car basically has an entire engine in pieces sitting here in my house. It's been a project that neither me nor my dad have the time or the ability to take on (assembling the whole engine and swapping it) and we finally found a shop nearby that's going to do the whole shebang for ~$1000. Which is worth it to make sure the job is done right, imo. I'd rather have it done and move on to projects on the car I CAN handle myself.
Today I took an inventory of parts before I send it over, and I figure I'll share because it's fun to nerd out about this stuff:
What I am still unsure about is how I am going to cool this beast. I have looked at BeCool etc. and they want a mint for their radiator/cooling setups. I was hoping to see some similar combos/setups. I was thinking the stock radiator, maybe recored with a good shroud and an electric puller fan should work, but anyone else have any suggestions/ideas?
This build has taken a ton of thought and planning and I am finally satisfied that I have a nice solid combination that will never need any major changes. I had to scrap the 800CFM double pumper I got from the swap meet when I determined it was likely too big for my needs.
Anywho, feel free to comment or advise me on this. I am going to be dropping it off in about a week to get the engine swap started.
It also occured to me that the 2.5" dual exhaust w/ x-pipe and Spintech Mufflers, Hooker Comp headers might not breath well enough for the new motor. Should this be OK or will I be choking it by not going to 3"? I'd like to reuse the old exhaust to save $$ if at all possible.
Thanks guys!
I am expecting about [email protected] RPM, [email protected] RPM. 411tq @ 2500 and it only drops below 400 at 6000rpm, per the engine simulators I've run. I have looked at similar builds that have lower end parts and put out more power than I am hoping for, so I think my figures could potentially grow with good tuning. This should be perfect for my somewhat heavy car (3600-3700 lbs) with an auto on the street.Brand Notes
MILODON Milodon Oil Pan kit w/ windage tray, pickup
MSD MSD Ignition Control 6A
MSD MSD Street/Strip Pro Billet Dist w/ Vacuum Advance
Fel-Pro Oil Pan Gaskets
Edelbrock Intake Gaskets
Fel-Pro Exhaust Gaskets
Fel-Pro Valve Cover Gaskets
Fel-Pro R.A.C.E Set 1969 351W
Fel-Pro Head Gasket
Melling High Volume Oil Pump w/ Hardened pump shaft
Melling Oil Pump Screen
Comp Cams Ford 351W Pushrod
ARP 12 pt accessory kit
March Underdrive Pulley Kit
Edelbrock Chrome High Volume Water Pump
Prothane Urethane Motor Mounts
Crane Energizer Rocker Arms 1.6 Ratio w/ 3/8” studs
Comp Cams Magnum 280H Hydraulic Flat Tappet Cam/Lifters (.512/.512 lift 230/230 dur 110 lsa)
Edelbrock Performer RPM Air-Gap Intake Manifold
Demon 750CFM Speed Demon – Vac Secondary – Electric Choke
Airflow Research AFR185CC heads, 58CC chambers
Short Block
351 2 Bolt Block
Hi-Nodular Cast 4.00” stroker Crank (408 ci total displacement)
5140 Forged I Beam Rods 6.200” long w/ ARP 7/16 Bolts
Total Seal Max Moly Rings
Clevite Tri-Metal Main @ Rods bearings
Probe Forged Pistons 19.3cc Dish
Externally Balanced Flexplate and Damper
Thanks guys!
