New to the forum here and new to my 1969 Cougar xr7. This car originally was yellow with a 4 speed.. Currently it's an orange eliminator clone with a ford crate 302 and automatic. I have been working on switching it over from manual brakes to power brakes but ran into some issues. When I bought the car it had all new 4 wheel disc brakes with a new master cylinder and porportional valve. I picked up a pedal and brake booster, and got those installed easy enough.. But now I have some issues. While trying to fit the master cylinder onto the booster there is not enough clearance to swing past the suspension hump making it impossible for the master to attach to the booster. I rounded the corner off the porportional valve bracket (mounts under the master) and I can ALMOST get it to make the swing... But no go. Also I noticed even if I make the swing, the brake line inlets on the porportional valve will be pressed right up against the suspension tower making it impossible to run brake lines. My questions: do I need a particular master cylinder to make this work? Do I need to mount my porportional valve elsewhere to make this work? And after installing the new brake pedal the passenger side brake lights don't work. Below are a few pictures:
http://i42.photobucket.com/albums/e335/rileyfan88/image-2_zps1198cff9.jpg
http://i42.photobucket.com/albums/e335/rileyfan88/image-2_zpsa5158c20.jpg
http://i42.photobucket.com/albums/e335/rileyfan88/image-2_zpsdba9a9ec.jpg
*edit... When I said porportioning valve I really am referring to the distribution block.
