hello. time to get the 69 galaxie back on the road after a few years sleeping in the garage and need some help finding parts.
1). does anyone know if there is a new repoped gas tank available or if other years will fit? as usual the 69 is the red haired stepchild in that i've found 71 and up and 68 and down but no 69.
2). anyone make prebent fuel lines?
3). i also need a headliner any suggestions as to a good supplier. i did find carpet available easy enough. does anyone here have a preference as to a good company to order from?
thanks
scott
Check Advance Auto Parts. They carry a Spectra that should be a perfect fit. Used one a couple years ago in my Marquis and it worked well. I would suggest ordering the rubber inlet tube seal from someone like Dennis Carpenter or Auto Krafters before you start the job. It would be a good time to replace the sending unit too.
