has any one ever changed a 69 Mach1 over to rack+pinion steering.If so what was used.Its a 351C 4spd car.
There have been numerous discussions on rack and pinion conversions here. The consensus is that you can use Rod and Custom Motorsports weld in cross-member/Mustang II suspension which uses rack and pinion OR there is a WEB site that someone has done a lot of rack/conversion homework on OR there is the expensive unit made by Total Control.
Good luck and have fun. Here are the URL's:
http://home.pacbell.net/ssixto/automotive/R&P/R&P.html
http://www.totalcontrolproducts.com/
http://www.rcmotorsports.net/
