Looking for a replacement fuel pump for my 69 and each time my parts supplier brings in a pump it has 5/16 inlet, the body of the pump is much smaller than mine and the replacement arm is longer.
I know my pump is original as it has my build date stamped on it, I bought the car from the original owner and the car is 99.9% original with the exception of a solenoid switch. The original fuel pump has CAR bure TER stamped on the side with 0-1719. The 1719 is inside an oval. My date code of 25C9 is stamped on the flange. It also has 45679 on the other side of the mounting flange. We checked the Carter listing for pretty well all years / applications and it keeps coming back to the puny Carter#M6588 which shows applicable from 68-72. Anyone run into this before?
thanks
