Wide ratio, tag Rug m3, toploader worked fine when pulled 20 years ago to install automatic. Comes with super shifter which needs a little work getting into reverse. Forward. Shifts good. Problem in shifter cN put trNny into reverse easily. Asking $750 plus shipping
Do you still have the RUG-M3 transmission? If so, can you send photos of the casting numbers and date codes from the main case and tail housing? I'd also like photos of the riveted ID tag and of the gears with the top plate removed if you don't mind please. Thanks
Sorry, sold it about three days ago
