Hi
I just replaced my dash circuit, all bulbs in dash. The right side of my Tach doesn't light along with thr right red warning light. Help!?!?!
Sounds like its time to break out a DMM and check for power to the bulb, and make sure the bulb hasa good ground. Of course you wil read source voltage on the power side with a voltmeter, and you should read no more than .02 ohms or resistance on the ground side circut(no power on the circut and read from the bulb to where it has ground)to make sure there are no opens or excessive amounts of resistance in the connections and wires
