I just had my worn out leaking control valve replaced with a brand new unit along with new hoses to the cylinder and idler arm. With the car on a lift,turned wheels lock to lock several time to get air out of the system. Also had the front end aligned.
Took it out for a ride, doesn't wander like it did but when I make a gradual turn, left or right, it doesn't react till I get the steering wheel about 10-15 degrees from center then it dives in that direction. I cannot turn the steering wheel at all if the car is on the ground sitting still.
It's a brand new valve. Did I get a bad one??
