Hey guys movin the Batt to the trunk. Got the Summit relocation kit. Ive read your suppose to run the battery plates parallel to the body if I run it this way it runs against the body instead of long way w/ the body . My ? is for those who have done this on 71-73 bodies did you mount it in front of the tank towards the rear seat or farther back. theres not a whole lot of room if I go in front of the tank to work on the top side of it. & the frame rail runs pretty close
Any boby got any pics ??
<font size=-1>[ This Message was edited by: 427sidewinder on 7/11/06 6:35am ]</font>
Banned
Pass in the area just behind the tire. And mount it the direction you said with the plates facing to the side. Might want to look into a shutoff switch too.
Thanks for the info, Got it in! Ended up like 9" from the Taillight panel on pass side behind rear tire. J-bolts kinda close between the frame & tank.
Used 2 Ga. all throughout, Also on engine to frame for ground
