Hello everybody, I've been in kind of a pickle. My truck has a great running 360 with flow tech headers on it and that's about it. It has original tran being a 4 speed gr gear. 32 inch tires stock rear end.
Now that you know what I'm dealing with I have a few questions. I am building a motor that will perform above my own standards and that will at last the rusty old ford body. In 4th gear I top out at about 65 without taching her up too much. I'm trying to raise my 0-60 Time, hp, and top speed. Basically I want the balls to the wall street truck. Doesn't matter if I get 3 mpg as long as I don't have to raise my compression because the stock heads are the best for the 360 but you knew that. Anyways I'm trying figure out what's the best set up for the 360 to keep it passing everything but a gas station. As in cam, intake , carb(cfm), rear end, and all the goods. If I had to change my cr or have a better choice than stock heads throw it at me.
Now the good park is I don't wanna be 80 and finally save the 12k it would cost I'm trying to do it near future. Thank you for looking. Any and all opinions and information, besides gm fans, will be considered. And if you have any questions on some other specs I'll be happy to figure them out for you.
