i have a 85 econoline 351w the motor is dead r.i.p
i found and am in process of pulling a 73 351w out of a car
after looking at the oil pans i noticed that i'll need to use the oil pan off of the econoline, i have taken thought
and have guessed that i'll all so have to change either
the oil pump sump or both oil pump amd sump right?
can any one answer this question ?
<font size=-1>[ This Message was edited by: 85econoline on 11/28/03 10:23pm ]</font>
I had to convert to the rear sump pan on my 460 in Queenie's 55 Effie ...
It required a totally different pump and pick up on the 460 since the direction the pickup tube has to come out of the pump is different.
I needed: ... pump ... pan ... pickup tube ... dipstick assembly ... to make the conversion. I assume the 351W will be similarly designed.
If you have both complete motors you will have most everything you need I would think. Obviously, a new pump would be in order
Larry Madsen
Las Vegas Nevada
<font size=-1>[ This Message was edited by: monstermach on 11/29/03 1:24am ]</font>
Discussion Starter #4
the engine swap has gone quite well , had too look for
parts off of older econolines , soon very soon the beast will be back on the road , my van is my lifeline 85 econoline van was 4v ho but now 2v , allways remember
kid's own Chevys but when we all grow up we buy FORD'S
FIRST ON RACE DAY!!!!!!!!
