So awhile back i had to slam on the brakes to avoid being demolished at by a red light runner. the car died. i finally got it started and ever since then it has sounded like im losing a cylinder at times. sometimes it runs good. other times it wont stay running for more than 10 minutes before idling down and just dying. the car has a new intake, carb, spark plugs, and fuel pump. ive adjusted the carb several times to lean it out, and make it richer. neither have solved the issue. My dad says to replace the ignition system on it. As he believes the spark is weak.
any help will be greatly appriciated.
