I'm just curious, the seat in my 68 is ruff. Its just a driver not a show car. I found a 73 LTD in a junk yard, seat is in real good shape and close to the right color. I was just wondering if it would be a direct bolt in. I'm probably going to buy it either way.
It might but it would be a fluke most likely as 1973 was the year they totally redid the full sized cars. If the seat brackets are the same width apart you might be able to at least use the front mounting holes and then drill another for the rear etc.
If you do get it post your results here as it would be good reference materials for others
