1 - 8 of 8 Posts
I am in the final stages of a frame off restoration a '74 Bronco for my brother, and I need some suggestions. It is going to have some 31" tall tires and a 4" lift. It has the original 302 with a 268 H cam, Performer intake, Autolite 4100 and Headman headers. It has a C-4 with an un-determined stall speed. What would be a good choice? It has 3.50 gears front and rear. I want to know what a good gear will be with the 31" tall tires. I don't think the 3.50's will cut it as it will probably be gutless on the low end. I am thinking 4.11's, but I wanted to see what anyone else thought. It is pretty much going to be driven on-road with an occasional trail ride. It will be primarily driven on the freeway to my bro's work, so the RPM's will have to be reasonable.
If you plan on staying with 31s, the 4.10s will work good, but really, anything from a 3.73 to a 4.10 would be good. 3.50s are just a little high.
My truck has 35s most of the time with 4.88 gears which isn't quite as low as it sounds. When I have 33s on it, it's a little low, but with 35s it works good.
http://www.offroaders.com/info/tech-corner/reading/mph-rpm.htm
This will get you started. Remember a automatic with a non lockup converter will slip a little at cruise RPM, so take that into consideraton.
http://www.s104x4.com/Content/TechArt/javacalc.htm
I also think the 3.50 will work fine with 31's to me it wouldn't be worth the time and money to change them out. I run 4.10 in my 74 bronco and run eather a 33,34,35 inch tire and its fine. I think with the 4inch lift though it won't take long before he wants some 33's
Like already said, the 3.50 will be nice all around with 31" tires. I run 4.11 with 35" tires and at 73mph im at 3000 rpm's. If you want to drive it on the highway i would put in 3.73's even with a 33" tire you still have nice setup.
If its for street driving mostly and for fun go with 4.11 and a locker.
I have a 74 with 31's and 3.50 gears, and it is a good combo. I have a 351 in it now, but when it had the 302 it was still a good combination.
hey F-15 you're just down the road a bit from here. It won't be long before you'll be wanting 33's on your Bronco. I'd drop the cam down a notch and run a tighter converter for those steep downhills when you come to the AZ "sky islands".
You can keep your gears with a lower grunt cam and you'll have more than enough torque off-road in low range.
The short wheel base 302 Bronco is probably one of the best off-road rigs ever designed.
Bob
1 - 8 of 8 Posts
