Mainly, where are the drain holes? I've got a 75 Ranchero, but after running the AC a while, I start to get water dripping on my feet. This screams to me that I need to clean out the drain holes for the AC box, but where are they?
Banned
should be on the engine side of the firewall just under the heater/AC hoses. Just a little drain pipe. Probably leaves, pine needles, etc plugging it up. Big cause of rusted out areas in the cowling.
Alright, I tracked the problem to be water from SOMEWHERE in the dash, I'm thinking condensation from the outside of the housing, maybe? It runs along the bottom of the dash...
My guess, maybe the case itself has a leak...insteak of it draining out in the engine compartment?
Worse case, take the dash out, and replace the seals going from the box to the firewall, and check the ac box itself for signs of water leaking.
