Ive had a problem with my car idling to low when in gear so today I stuck a 750 edelbrock carb on just to see the dif between it and the 6oo I have been running.I know its probably too big for a 352 but I was to the point of trying anything. I believe it is much better. I couldnt drive today because its raining here but well see . It cant get much worse gas mileage as I was only getting 8 or 9 mpg with the 600
750 isn't that big for a 352.
Though in my limited experience I've seen a lot of cars respond well to a carbuerator most consider to be "too big"
<font size=-1>[ This Message was edited by: thekingofazle on 7/6/06 9:09pm ]</font>
If you read Vizard's stuff, he says there is no such thing as too big of a carb. Might be a bit misleading, but if if you have the signal required (which you probably have a better signal with a mild 352 than a built 460 would have) then you are good to go, run it
Tried it out today and was pretty happy with the results. Plenty of power when getting on it and a decent idle . It has a surge at cruising about 45 to 50 mph. and I need to transfer the electric choke over to the 750 but I will try to fine tune it and run it awhile and see what happens
I bet thats a lean surge - a bigger carb will get less signal than a small one, requiring more jet to deliver the same amount of fuel.
Carbs act on the premise of restricting airflow. Like My427 said, if you can get a bigger one to meter fuel effectively, you can go as big as you want. Essentially thats all EFI is - a no-restriction carb (throttle body) and jets that meter at any vaccuum signal. (injectors) That's part of the reason fuel injection can give you a little bit more horsepower up top - because you're not restricting the intake in order to suck fuel out of a venturi.
Vizard has some great articles on carbs. There is no "formula" for carb sizing - if there was, it would be based entirely on engine vaccuum and air-speed parameters across the whole of an engines operating range.
It just happens that many engines are designed similarly enough that a "rule of thumb" formula has evolved that can get a carb close enough to work decently.
The world rarely follows formulas. The best ones can get pretty close, but there is no substitue for chaos - nothing happens exactly the same way twice.
Well I got the choke installed and drove around a little more . Still a little lean at part throttle so I plan on getting a calabration kit ordered soon
