Stock Ford, 8", 2.79 ratio, out of a 1979 Granada. Bought this used to convert to a V-8, 5 lug in a 1966 mustang. With the rearend assembled out of the car, turning the yoke- the axles dont turn. I disassembled and on the bench, out of the case-I turn one axle and the opposite side does turn the opposite way(I believe this is correct). but turning the yoke the axles still dont turn. Would some one have an idea what might be wrong. Thanks
the carrier is out of the housing-the ring turns when the pinion is turned.
<font size=-1>[ This Message was edited by: juiceman39 on 5/13/06 6:39am ]</font>
most likely the ring and pinion is garbage. sounds like the diff should be fine.
<font size=-1>[ This Message was edited by: kmracer on 5/12/06 8:44am ]</font>
