Just about it. I don't want to confuse anyone if mixing early and late models, as that rule is for everything including 5.0L (1980+ manual). So here is the whole story (early
and late SBF), just so the wrong combo isn't assumed:
- Long nose all auto except oddballs (Mustang II etc.)
- Long nose all 157T manual cars 1980+
- Short nose some pre-1980 157T manual
There are other oddballs besides the MII, like some Bronco 302s, late trucks and vans, and a few others. That's why I stated about the long/short drive gears, as he
could have one of the early short nose 157T starters. Still not sure? See crappy pic below. At the end of the day, the SBF's with ring gears less than 1/4" from the block use the short nose, and the ones with ring gears further out use the long nose. It's easier to lump the short/long fit depending on what years you're talking. There are only a handful of SBF starter types, and just two of them cover 95% of anything we see. Maybe I should just change my rules to whether it can fit a pencil or not... LOL
So, if you want a late-model PMGR mini-starter for your '67 302 with a C4 or AOD conversion for cheap, just grab a long nose version from perhaps a '92-'95 Mustang 5-speed or auto, or an '89-'97 T-bird 3.8L V6 (the 3.8 is SBF pattern), or a '92-'97 4.9L (300ci) F-150 pickup auto (yep, SBF pattern and long nose again), or ...
Here I can't even fit a standard pencil between the block plate and this 164T manual flywheel, so it definitely takes a short-nose starter:
