1 - 14 of 14 Posts
You might try some out of a Maverick or '63 Falcon V8. Those are the narrowest 8 inch, 5lug rears Ford made.
That MII rearend should measure 57 inches flange to flange.
The Maverick 8" is 56.50, so each axle would be be 1/4" shorter, but they should still have enough engagement to work.
Axles from an 8" from a 65-66 Mustang should work also. That rear is 57" flange to flange. So the axles would be 1/8" longer on each side.
Check this link for widths:
http://www.mustangsandmore.com/ubb/FordRearDimensions.html
Later,
David Cole
What I did was to swap a 9" from a 67-68 mustang It was the perfect length. Even the spring pads were in the right location. I just eliminated the spring isolator set-up. But I used a 1/2" spacer under the rear and retained the sway bar. Now it's 5-lug. I bought a set of 5-lug rotors off Ebay for 55.00.
maverick axles will not work. The mavericks have one short and one long axle, whereas the MII axles are nearly the same length. I just bought a MII rear for the axles, just to find out they wouldnt fit the maverick rear. Hope this helps.
On 2002-03-17 22:08, radracing wrote:
what 9" would go under a 64 Falcon V8
Alan
Click on the link in my earlier reply. 3rd from the top of this thread. There are several 9" rears that are very close to stock widht for a 64 Falcon.
Later,
David Cole
1 - 14 of 14 Posts
