I am having a problem with the rear end seals that seal the axles, they are leaking. The one on the pass. side mostly. can some one tell me the proper way to seal these. Are there two types and I have the wrong one or what. They leaked all over my drums and rendered them useless. Please tell me how to fix this once and for all. Thanks
If you seem to be going through seals alot, you might want to change or clean your vent out. The #1 reason for seals to go is pressure building up.
Another thing you may consider is a seal/axle sleeve. If they are original axles, the years have taken their toll and wore down just enough to weep.
Fred
