My '95 F-150 overheats at highway speeds even though I have replaced the thermostat and water pump. The pump was leaking, being the reason for replacement, and I changed the thermostat just because of the high mileage on the truck. But now, at sustained speeds at 55+, the temp. gauge pegs for 10-20 seconds then falls back to normal temp, hangs there for a couple of minutes and then starts climbing back to the high temp side of the gauge. Just driving in town in stop-and-go traffic the temp. stays in the normal range. Could the lower hose be collapsing? I've kept an eye on coolant level and that's at normal level. I would appreciate any insight to this problem that anyone might have. Is there a way to replicate driving conditions in the driveway? Maybe place the truck on jackstands and block the airflow through the radiator.
And I would advise against trying to run the truck at highway speeds on jack stands. That's a recipe for disaster.
Do you have a flex fan or a mechanical clutch fan?
Thanks for the reply.
I didn't mention that I replaced the radiator about four years ago and I do try to change the coolant every other year. The coolant looks clean. This truck has been a good one, bought new, and now has over 228,000 miles. I try to stay on top of the preventive maintenance.
Have you properly purged the system of air? Maybe at highway speeds the water pump can't push the air out of it that collects there.
