I have a 97 cobra 5 speed and it won't start. I've had jumper cables on it and still won't start turns over for a second or two then nothing try it again and all it does is click plz help me out
Sent from my SAMSUNG-SGH-I727 using AutoGuide.Com Free App
not enuff battery power to turn fuel pump injectors etc...
charge battery or get another one...then try again....
Let it charge up a little bit. So, with the vehicle providing the charge, let it run a little bit before starting the Cobra. Also, to make sure the donor isn't weak, while trying to start the Cobra, make sure the donor has a higher idle (1500-2000 rpm).
