My cruise control is inop. I have two questions:
Apparently there is no Cruise Control indicator lite on the dashboard for this year. I can not find any evidence of one in the owners manual. It appears that by, at least, 2002 they may have had such a lite.
It is said that the most common failure of the cruise control is in the failsafe? cut out switch on the brake pedal? If so, how do you test that switch to see if it is bad?
The switch on the master cylinder has been replaced so that is not an issue. All three rear brake lights are working and I also checked the #'s 6 and ll fuses.
I would hate to pay $70 just to have this system diagnosed, only to find out that it is just the brake pedal switch.
