I put a Vintage air system in my 61 Starliner and 61 is the same as 62. They do not sell a 62 "Sure fit" package but they will put a package together for you if you contact them.
They do not sell a sure fit package because there is some minor fab work required get the evaporator unit installed if you go with a behind the dash unit if you are installing a Air/Heat package.
They also sell a unit that that mounts under the dash like the original ones did that is an Air only unit and all you can not buy from them is the old York compressor mounting bracket and any idlers if so equipped.
Scott...
I had a Classic Auto Air installed in my '62. I think they had to customize it quite a bit.
Not sure how happy I am with it yet - it's a bit of a burden on the belt system and the radiator. Actually considering removing it...
The heater part works fantastic though!
