I have a 68 cougar and cannot get full throttle out of my carb linkage.
I have dual fours on a tunnel ram. The carbs are 450 holleys set up in-line (same as a normal carb, they are not mounted sideways) I want to know the proper way to get the throw on the linkage right. Can I use a cable like newer cars? If so how would I make that work with the stock pedal which is a mechanical design?
The problem with the mechanical linkage is that it doesnt have enough throw. It will not open the carbs up to full throttle.
I have never attempted a pedal switch. Should I order a set up from a catlouge or try and piece one together from the bone yard. Would a 69 mustang set up go in easiest?
Blue, I havent tried to bend it, because I cant imagine how that would cause it to get more throw. It would start and stop at a different point, but should travel the same distance.
70, thanks for the advice, is Summit the best place to get that, or should I just call lokar directly?
If this uses a bellcrank arrangement at the base of the ram, you just need to fab a replacement bellcrank with longer arms. I'm running my stock pedal on a Funnelweb, which is 7 1/2" tall. I just made my own guide and bent up the appropriate shape out of 1/4" rod. A rod end and some engineering and it's all fine.
