Is there a way to tell if the ACT sensor needs replaced?
It's for my '88GT so I don't have a check engine light.
I heard that if they go bad, it will go into "limp mode".
This has probably never been replaced so do they go bad after a number of miles?
what code do you have? if your engine light is on, there will be a code. get the codes read before you start throwing parts at it!!
'88's don't have engine lights
Ummmm, you can always pull it out, stick it in the fridge for a while, pull it out read the ohms, and apply heat with a hair dryer while reading the ohms. The ohm reading should fluctuate, if not its bad. But, still have the codes read that may not be your problem or you may have more problems.
Chris.
