Does anyone know if you can add a trans kick-down lever to a Holley 650DP?
If not, I'm sure some of you guys have fabricated something clever - any ideas would be appreciated.
I'd hate to have to downshift manually every time I punch it. I'll wear my shifter out in about a week!
Thanks!
________________
JC - '68 Fastback
<font size=-1>[ This Message was edited by: JC on 1/30/02 12:05am ]</font>
Thanks Racerguy, but...
I'd hate to tear down a brand spankin' new carb and install the throttle shaft from an old one.
I do have some old 600 vac secondaries around - will the shaft interchange with a 650 DP?
Anyone have any other ideas?
check out Lockar, I don't know about the DP, but for my Edelebrock 600 it worked great, and when I switched to a Holly 750 it went right on, minor adjustments, and looks good.
do you really down shift that much? your trany would wear before the shifter......
I'm not certain of the DP Holley carbs but when I installed a 600 holley (vac. sec) a long time ago on a previous granada I had I bought a kit from holley that allows use of the ford kickdown rod. From my recollection you do have to change or take out the throttle shaft to install the linkage that lets you adapt the kickdown rod to your holley carb. Hope this helps.
Rather than remove the whole throttle shaft i have done a few by grinding the end of the shaft that is peened over to hold on the linkage just enough to remove the end plate,get hold of an old base plate with the k/d linkage ,fit it on the put the original linkage plate back on with a couple spots with a mig welder just like the barry grant carbs have..You usually have to use the nylon bush + return spring that goes with the k/d lever.Hope that makes sense..
