Jim
here are a few problem spots to look for. The rear frame rails where the rear leaf spring shackles mount, The front floor and toe boards and the worst area would be the RH front frame rail where the battery tray is. This area can sometimes be very bad, especailly the mount pad for the RH strut rod bracket. Also check the rear quarter panel edges around the wheel wells and trunk drop offs.
If at had a V8, it will have a 8" under it ( I think 6cyl also) unless it a "K" code , it will have a 9". All 62-65 will have 5 lug wheels.
