I was wondering if anyone has seen first hand any numbers on the AFR 185 Renegades. Now before everyone tells me that info is out there. I will tell you why I am looking and what Im looking for. Yea the Renegades are cnc'd but the numbers that AFR published are with a .060 over bore. If anyone here has spent any time at all on a good flow bench you already know unshrouding the intake with another .030 makes a rather big improvement. And most budget guys using a late model 302 roller block are not boring it .060 over. So you buy a set of the AFR 185 's and the numbers dont get to the published ones you read. Well if you were using a big bore block and went .060 or more they would probably get there quite easy. Anyway I havent seen any flow numbers at all from a 0.30 over motor and was just wondering if anyone here had. Thanx guys.
