I have a 2001 F150. When I turn my directional knob to the left for Panel, Air, or Max air, the louver in the dash will not redirect the air from the defrost. The air coming out is cold, but I get nothing from the panel. Has anyone encountered this before. Thanks
In another vehicle, I had a vacuum leak in a vacuum motor. See if you can find the vacuum line going to the control, and pull a vacuum on it with a pump or one of those one man brake bleeders. If it will not hold vacuum, that's the problem. The rest of the problem is getting to the vacuum motor. At least you know which one it is.
Banned
Either a vaccum laek at the motor or a hose. If not you probably have something in your A/C Heater box jamming the blend door from moving. At a Ford dealership fished allot of pens and pencils out of them.
