Yes. The "check engine" light might come on but probably not and if it does it will probably still run ok. I dont think you'll gain anything by removing it though.
If it still has the converters on it you should run the air pump. It puts air in the exhaust so the converters will burn the unburned fuel. I would think the converters would clog up in time without the air pump.
True, if it still has the convertors on it it will melt them down pretty quick.
You don't gain a whole lot but every little bit helps I guess.
