Airbag Removal
1864 Views 4 Replies 3 Participants Last post by  coolreed
OK, OK, OK,..I want to get rid of that Airbag Steering Wheel in my 92 Mustang and replace it with a nice Grant unit. I do not care about the airbag. Surely, someone has done this before. I have heard there are complications with the horn if you do this. And Grant says they do not have an steering wheel adapter (bs). Any insight or help out there?
See less See more
Your airbag system will be disabled if you remove the airbag. You quite possibly will not pass inspection without it. If it came with it, you need it to pass.
I don't care about the inspection. I can always reinstall it.
I did it. No problem. If you still haven't done it, I can help. Just buy the adapter kit for the non airbag car. It doesn't look as clean as it would on the non airbag round steering coluem but it works. I also pulled all the sensors under the hood behind the headlights and such with no problems. Safety sucks!!!
The word I get is disconnect the battery and let the car sit for an hour or so. (I am in no hurry so I will let it sit overnight.) There are two screws behind the steering wheel and you remove them and Viola! You are on your way. I am not sure about what the sensors look like behind the headlights. But I will find out.
I cannot stand my 92 Steering Wheel and I intend on Open Tracking a little. I want a better feeling steering wheel. In fact I would prefer a 89 model Tilt Column or maybe a Flaming River or I Did It Steering Column. If any of you Mustang Guru's have some info on the Steering Column replacment feel free to respond.
