I'm planning on buying the longacre camber caster gauge so I can set the alignment on my Torino myself. Anyone know where I might find a listing of the factory alignment specs? I suppose for the most part it is pretty straight forward but it would be nice to have a guide to work with on the caster setting. I think I might have a tendency to put too much in it after having had my T-bird that needed like 5 degrees.
Remember that the specs listed in a manual are for bias belted tires that originally came on the cars back then, not modern radials. You have to make allowances if you're running radials, especially on the caster. I like to run 1 1/2* - 2* positive. If you have power steering will make a difference, too.
