I have a 88 f 150 with a 400 big block I just put in it. I'm trying to put a one wire alternator on it to bypass putting a computer on it. The only one that makes a single wire is gm. The sizing is very close and it should bolt up if I use a different sized spacer on one of the mount bolts. Should I do this or will it run my battery down when I have the key off?
Sent from AutoGuide.com Free App
You can check summit or jegs, they make a one wire gm style alternator with a ford case to mount right up. Put one on my 289 and works great. there are diodes build in to keep from draining your battery
