1 - 9 of 9 Posts
I took pictures but obviously not good enough. I have attached two pictures and need to know what wires go where.
This is the Back of the alt. I have a Batt terminal, a ground termanal,FLO terminal and STA.
These are the wires I have available. White wire small terminal, White and black striped small terminal,Black with red stripe small terminal, solid black with medium terminal and black and red stripe with Large terminal.
Just need to know which ones go where. Thanks in advance.
This simple (now non functional) NASA schematic I found will help you out. Photo taken from deep space. :)
Wire #1 Grounds to the BLOCK or the head, your choice.
Do NOT mix up #4 and #2 or you will burn out your regulator.
White with Black stripe is the STATOR wire and White is the FIELD wire.
Happy driving.
Nicely done satellite shot. You must have a lot of pull at the NSA.
:D
1 - 9 of 9 Posts
