For your viewing pleasure:Hair and grease remover???? LOL
Maybe you shouldn't have used that Rogaine on your car's grill?
Was that a thumb's up on the Hair/Degreaser method?I n the short time I've had my 64 Galaxie, I've polished the grille, all the bezels,and misc. trim, and I used the Hair and Grease method. I really think any paint stripper would work to get off the original coating on the aluminum. It's tough to get out the big rock dings in the grille ,but I worked my way up to 800 grit paper sanding out some scratches. I used some of the Eastwood compounds to smooth out the sanding with the buffing wheel on the drill.
If you do not have to sand anything, just use a nice soft buffing wheel and the Mother's Mag & Aluminum polish,that does a pretty good job. One thing to remember, work the Mag polish wet, don't let it get too dry as you are buffing it, stop when it starts looking dry, wipe it off and put more polish on and go at it again.
Oh yes definitely, I have a gallon of in waiting ! You can't start to shine the aluminum until you get the anodizing and clear coating off of the aluminum. I thought I messed up the first bezel I did,not realizing there was a clear coating on the aluminum bezel.You can tell when the coating is off when the aluminum piece starts to shine.Was that a thumb's up on the Hair/Degreaser method?
I have an old, spare 64 grill in my garage.Oh yes definitely, I have a gallon of in waiting ! You can't start to shine the aluminum until you get the anodizing and clear coating off of the aluminum. I thought I messed up the first bezel I did,not realizing there was a clear coating on the aluminum bezel.You can tell when the coating is off when the aluminum piece starts to shine.
Make sure you do it outside or in a very well ventilated area ! the fumes are bad....I did my grille, and it takes a lot of time,but very well worth it. I polished it all by hand, a buffing wheel on a hand held apparatus would speed things up .I have an old, spare 64 grill in my garage.
Think I'll give it a try when fall breaks.
Thanks for the tip.Make sure you do it outside or in a very well ventilated area ! the fumes are bad....I did my grille, and it takes a lot of time,but very well worth it. I polished it all by hand, a buffing wheel on a hand held apparatus would speed things up .
