Maybe this is stupid of me to ask, but why did Ford go away from having the amp guage in the clusters to just a voltmeter?
Just curious...was browsing a post about the G3 conversion for one of the guys in the torino section.
I am going to for the time being upgrade the alternator on my '72 Gran Torino Sport to the 100 amp unit because I have a stack of good units, plus a near new unit from my last truck and a NOS alternator harness for it.
I have debated about hooking up the ammeter circut for my original sport cluster but don't want to burn up the guage or worse, fry the wiring by accident.
With an ammeter all of the electrical current used by your car has to go through the meter, with the exception of the starter motor. This wasn't a problem back when the alternators, and all of your car's electrical system, were rated at only 35 - 50 amps. Nowadays cars have 100 amp and higher systems which would require huge gauge wire to be ran to and from the ammeter. Expensive and a fire hazard. Plus if an ammeter craps out (opens up) the rest of your car has no electricity because it is wired in series with the battery. A voltmeter is wired in parallel with the battery and won't affect much if it goes bad. A voltmeter gives you more usable information about battery static/charging voltage than an ammeter that only shows direction and rate of charge.
70 Maverick Grabber, 5.0 (Performer RPM heads, intake & roller cam, 600 Holley, long headers), T5, 9" w/3.89:1
<font size=-1>[ This Message was edited by: bmcd66250 on 8/23/06 11:46pm ]</font>
Thanks for the info...my memory about how ammeters work is pretty limited, and I was pretty worried about something like that.
At this point, I am running a 60 amp unit, so it's not an issue, but I plan on upgrading it soon
