Hey guys- first post on here- theres a tapping sound, pretty loud, coming from somewhere in my car. It still goes off while the engine is off, and i can hear it best from inside by the glove box. My best guess is that it is the wiper motor somehow, because the wipers don't work either. Anyone has this or a similar problem?
Heater blend door? Does it still make noise with the heater off? When you hear the noise, does the alternator needle react? Does the heater work correctly?
I have this problem with my 94 LX. Poor heat, and the door sometimes makes a lot of noise trying to open/close.
or, Power antenna motor?
Antenna work OK?
Another problem with mine. antenna is stuck in a halfway upright position (cable must have snapped), and, after I shut the car off, I can hear the motor running for a few seconds trying to pull the antenna down.
