Fresh rebuild of a 74 & 75 to make a good one.
Typical basic mods: Drilled #9, and did the Pump mod with a plug.
Tranny spins up fine, but only has 60psi.
Remove the vacume and it holds the psi at 60... no change, why?
It shifts early. However manual shifting it work fine.
<U>Please post any ideas.</U> How do I increase pressure? Or what do I check. (looking at a stuck spring in the valve body?)
THANKS for the help! (This isn't the tranny I showed with the AOD cluthces, that is the next build)
You have to increase the spring pressure on the main pressure regulator to increase pressure.
Stock pressure is considerably higher than 60 psi - where are you measuring the pressure?
Thanks for the help
Pulled the spring from another VB, and cleaned with hole with scotchbite. Now works great!
