I have a slightly used holley 600cfm with vac secondaries and when i put it on my freshly rebuilt engine it starts just fine but after a couple of seconds fuel pores out of the vent on the top of the car. I tried blowing air through the inlet to clear any possible particles out but it still floods. I have the stock ford fuel pump and a new fuel filter before the pump. Any suggestions/tips.
Sounds like the float is adjusted too high or stuck. Or there is something stuck/leaking in the needle and seat for the float.
Should be fine if you rebuild it adn adjust it.
Also be sure to have a good fuel filter prior to the carb. Holley's needle and seats seem to be very susceptible to crap in the fuel.
Just my .02 the float may also be cracked and filling with gas . so the needle and seat wont close
