Another obscure skill learned
1108 Views 15 Replies 9 Participants Last post by  Jazzmeister
5
Guys, I thought I’d share a little trick I learned yesterday with the help of the nice people at Auto City Classic. I am working on installing my windshield for my XL convertible and wanted to do the Carlite etching before putting the glass in for good. The new windshields always seem to have a very conspicuous marking on them (unlike the side glass that seems to print the required information discreetly on the outer perimeter where it is hidden when installed). In the past I’ve just lived with this imperfection, and ended up with windshields with two etchings on them in different spots. I tried heat, solvents, scraping with a razor blade. Nothing seemed to remove the stubborn and durable black transfers, so I was literally stuck with them. I reached out to Auto City Classics to see if they had any tips for removal of these. I understand they will date-code your class for you on request, so I thought maybe that had figured out a way to get this done. Well, they were nice enough to share with me that muriatic acid is, in fact, the secret solvent for this ink. Well, I just happened to have some on hand, and what do you know, it worked great. They also mentioned that a faint “ghost image” would still be there, but would polish off. I used some super duty rubbing compound, and removed all traces…check it out…
Road surface Asphalt Tar Font Sidewalk
Automotive tire Bottle Fluid Tire Plastic bottle
Road surface Asphalt Tints and shades Wood Bumper
Water Hood Road surface Asphalt Wood
…and now for a “proper” etching…
Asphalt Road surface Wood Font Automotive tire
Now, I know most guys don’t care about such things, and I also know it is federally mandated that this information is printed on glass. I have exactly zero times looked at a glass etching and felt a feeling of safety and security wash over me once I knew it was AS1 or AS2 glass. I feel like these logos and fonts just don’t fit the esthetic of a vintage car. Some day another weirdo may come along who is interested in removing one of these, so here’s to you, future traveler, glad I could save you some trouble.
See less See more
  • Like
  • Helpful
Reactions: 5
1 - 16 of 16 Posts
Very cool! (y)
Where did you purchase the windshield?
Very cool! (y)
I got it from Auto City Classics in Minnesota. I’ve had great experiences with them in the past.
  • Like
Reactions: 1
Where would I go to get the age appropriate stencil that says “Carlite” on it? Did you make it yourself?
  • Like
Reactions: 1
It was printed on the glass, and it is not for the Feds, but for you. Do you leave the Federally-mandated tags on pillows and furniture? :LOL:
Sleeve Gesture Font Sharing Photo caption
To be fair, some state inspections might require the markings, but I imagine yours still qualify. ;) You should change your forum name to "EtchEverything" or something.
See less See more
  • Like
  • Haha
Reactions: 4
Yes, I made the stencils. I have considered making these for others if they wanted on a limited basis.
I do much more than glass etching, but I have shared more of that because it is something others have not covered. If you guys are interested in my block-sanding, I can post lots of pics! ;)
  • Like
  • Haha
Reactions: 2
I’m always interested in seeing project progress. Even block sanding.
Granted your more obscure stuff is even more interesting.
  • Like
Reactions: 1
What is the type of acid used in the etching process?
A new lesson and something new here too. Boy you double whammied this time! :ROFLMAO:
5
I’ve been using Armour Etch. One bottle is a lifetime supply. It actually doesn’t identify the ingredients, but I’m pretty sure it’s hydrofluoric acid. It only takes about 1 min to 90 sec to get a nice deep etching.
Hood Motor vehicle Vehicle Automotive design Trunk
Hood Motor vehicle Vehicle Automotive design Car
and now for some real excitement…
Tire Hood Motor vehicle Automotive tire Vehicle
Motor vehicle Hood Automotive tire Automotive design Vehicle
Vehicle cover Wheel Tire Automotive tire Hood
trying to obsessively get the planes of each body panel in perfect alignment sighting down the car. My hardtop has the full-length moulding, but this bead is such a tricky (and important) feature looking down the side. I’m within striking distance. Liking my door gaps too. I’m sanding across all the panels and gaps on the whole side. I just needed to justify the quarter to door first…rinse and repeat!
See less See more
  • Like
Reactions: 1
I had a distant buddy and his wife doing parking lot car show window design etching 40 years ago, and they used hydrofluoric acid paste. They made some good pocket money while sitting around the shows. They used pre-cut plastic (vinyl) stickers for most stock stuff in window corners usually, like roses, geometric designs, club logos, anti-theft numbering, etc.
It's interesting what HF acid does not attack quickly for stencil stock. I wonder if the little hobby vinyl sheet cutters (Cricut?) can detail enough for this?
  • Like
Reactions: 1
I just recently picked up a PMK Diamond (Thailand company) Galaxie windshield from Auto City Classic.
It has no DOT marking. No marking at all. Nothing.
Should I be worried?
I wouldn’t be…that’s what I was hoping I’d get.
  • Like
Reactions: 1
1 - 16 of 16 Posts
