I have a tag off of my 2001 Mustang that came off my rear end. The top numbers are the same, but the last four are different. Can anybody tell me what spline my axles are?
its a tag what i thought to be off the tranny.
the top row on the tag is: S260A
the bottom row: 3 27 75 2B26
thanks
If it's a rear axle tag you're missing a set of letters. Otherwise it would translate to a 7.5" rear axle with 3.27 gears and open differential made on February 26, 1982, 1992 or 2002 at the Sterling Plant. If you have a set of letters like WFD-AX, that would verify all of it. Odd thing is that the date and plant codes are on the wrong lines as usually found on axle tags. Pic please.
