OK, this is my last new thread for the week I promise! I'm having issues with my turn signals in my 63 galaxie and I haven't been able to find the solution yet. I did a search on this forum and have tried just about everything that was mentioned. Here's where I'm at now:
First, my turn signals started acting up after I unplugged and cleaned some wiring. I went through all the connections to be sure they were solid but then started blowing fuses. I could get all the turn signals to work again by replacing the 14 amp fuse and they would work with the key turned to the On position. However, once I started driving they would blow the fuse.
Now, none of my turn signals or blinkers in the dash will turn on at all. The fuse is good and the wiring has been gone through in the rear of the car. I have looked at and tested a lot of wires under the dash but haven't found anything obvious....
Any ideas?
Any ideas?
