So, I'm finally getting around to replacing my broken antenna mast and I don't see any other way to remove it without taking the fender off. Anyone know a trick that I'm not seeing?
Should bot be necessary. Get out the instructions from the new antenna and follow them backwards.
The 68 should have a chromed escutcheon (cover) that is popped off and four sheet metal screws will hold the antenna body to the fender.
Yes, like posted prior and once you get it loose and pulled up slightly from fender, get your fingers on the wire that goes to the radio and grip it firmly and pull the metal part straight off. Took a pretty good pull with mine (never been off I guess) and it pushes right back in to your new antenna.
