I just noticed a few drops of antifreeze under my cougar with C4. Looks like it must have dripped out of the trans fluid lines that go to the radiator. About half way between radiator and trans there is a section of rubber hose around the lines, that is where it looks like it dripped from.
There should be only trans fluid in these lines right ? I know that is how it is on the 700r4 on my old suburban.
It appears only antifreeze, and no trans fluid is what dripped.
My guess is that antifreeze is leaking into the lines in the cooler in the radiator.
Should I just get a new radiator ? Is there likely damage to the transmission ?
Also, I have driven the car very little. It has a reverse manual valve body in it. It seems the only way to get it into first is to come to a complete stop, otherwise shifting into the 1st position, it stays in second. Is this correct for a reverse manual ?
