I'm 16 wanting to rebuild a 68 302 what mods should i do to it to make a pretty mean street machine
im not an expert or real mustang smart as half the guys in here, but ill get you started with what i can. im sure youll get some real good help in here. ok,some questions to consider: what do you have on it now? is it all stock? whats going to be the use of it(streetable,drag race,etc)?
i don't wanna spend more than 1500 to 2000 dollars for engine completely done. I want it for street driving but I want a pretty bad ass street car.
my suggestion would be to start with some basics, get headers, aluminium intake, upgrade your carburator i reccomend a Holley (maybe a 650 double pumper). replace your stock cam, i say go with a Comp Cam (research which size/duratrion is better for you). next i would suggest a trans pak/ shift kit improver(like a B&M). after this, any $$$ left over you can use to upgrade other stuff like maybe a better distributor/coil,wires,plugs, maybe even replace your fan with an electrical fan. good luck.
