ive got a ati damper,for my windsor stroker,lower pulley alignment off 1/2 inch,im calling ati again tomarrow with my specs,are yall running any spacers,this motor has turned into a cluster f...!sorry for the bitchin.matt
I'm am running a .975 spacer and a 2 groove pulley from a Bronco to fit my small block. The pulley started life as a 5 groove pulley.
67 Falcon 2dr sedan, 408W, C4 w/3500 stall, 3.80 w/Detroit. www.trailhed.com/Falcon.html
Anodize is making a comeback!
<font size=-1>[ This Message was edited by: 67falconer on 9/17/06 9:22am ]</font>
You should be able to find the correct spacer w/o any problems.
Seems like every damper I've used required a differant spacer for my set up
